Spark plugs on a 99GT
I have read some posts that said that you do not have to remove the fuel rails when changing out the spark plugs. Is this really true? Once I remove one of the bolts holding down the Coil Pack does it have enough give to remove it from under the fuel rail without breaking something? Can I get a socket on the spark plug to remove it? If someone has done this can you please explain in a little more detail? Sorry for all the questions, but if someone could share their own tips and tricks on this it would be very helpful.
Thanks,
Robert
Thanks,
Robert
RE: Spark plugs on a 99GT
you do not need to remove the fuel rails to change out the plugs, there is enough room to get a socket and extension down there, but its close. The rubber insulators like to stick, so you need to becareful as to not rip them when pulling them off.
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
