hi there,i have a 2001gt,but i have npi intake,i thought 01-04 had the
pi intake?if i get a pi intake will i have to get the additional
parts needed to go from npi to pi?thanks
my intake dont have the aluminum runner?its all plastic.
I'm gonna tell you what I told a guy over in 4.6L general:
Get a replacement, they run less than $200 with the aluminium crossover, from most online outlets. My brother's '99GT had the stock all composite manifold crack...that was an unnecessary PITA.
If you've got the $$$ to burn pick up a Bullitt manifold or even better, the aftermarket TFS Track Heat "equivalent" they'll run you about $800.
the first years of the pi were all plastic, my 2000 is all plastic. i want to say late '01 or '02 is when they switched over to the aluminum crossover.
do i need to get all the extra parts like american muscle says,
like the alternater bracket,heater hose,nipple for water pump,
and what gasket set,for pi or npi?thanks again,i just patched
it for now,until i find out all ill need.
I will have a used PI intake w/ Aluminum crossover for sale as soon as I get my car back from the shop and the SC is tuned and in working order. Came off of my 2003 GT with 84,000 miles on it. Just took it off a few weeks ago. Its an option.....
i will probaly get one from american muscle,but dont know if i need those
additional parts,like the alternator bracket,the hose and nipple
and which gasket,for the npi,or the pi?
you're taking off a pi intake for a pi intake with a different coolant crossover is all. so none of those other things will be needed. and pi gaskets.
