Throttle Body
RE: Throttle Body
Well, it depends. If you're keeping the stock airbox, filter, and duct, then 70mm is fine. However, if you're going with a CAI, then you can go 75mm. Also, with the CAI, you could switch the plenum (aka, upper intake). There are several out there. I personally like Accufab TBs and plenums, but they are the most expensive. Skip MAC everything and good luck to you.
the "mm" is the inside diameter of the TB.
RE: Throttle Body
You don't need to upgrade to a 75mm throttle body unless you have some type of forced induction. A 70mm accufab will probally be your best bet, unless you have a supercharger, turbo, or forced induction. The you can go up to a 75mm. Othewise the extra 5mm is not gonna do anything for you. I would do the throttle body and plenum combo if I were you (accufab). Good luck!
RE: Throttle Body
70 mm. A CAI is not forced induction. 75mm will actually probally hurt your performance more then help it. Look I'll make you a chart.
70mm- N/A vehicles with light/medium mods.
75mm- Forced induction vehicles, or heavily modded N/A applications.
RE: Throttle Body
Thats ok, you don't need to be sorry. No one knows everything about every car. Thats why you come here and learn. Sometimes I'm just a tad bit scarcastic. Don't take it personal. lol. Good luck!
