Stage 1 or stage 2 comp cams?
I know they stock them on americanmuscle.com and their prices always seem to be competitive.
I'm curious about this too. I was considering putting stage 2 comp cams in. I'm n/a, have a fair amount of bolt on work done, running 3.73's. Aside from replacing springs, is there any other mods that I really should or must have done before putting in stage 2 cams?
PTV is piston-to-valve correct? Do you just mean that the installation is very tight or is there actual adjustments that have to be made to get them in?
I've heard about the MHS Stage 2 Cams on these forums. Are they quality cams (never heard of that brand anywhere else...though I haven't really done much looking) and would it be a solid upgrade without PTV clearance issues rather than the CMC's?
If I'm going to drop the money on Cams I want to get the most out of it, so I'm definitely leaning towards Stage 2. I'm worried (probably because I have very little idea what it means..) about the PTV clearance issue..
MHS cams are gound by Bullet Racing, and they are among the very best in quality. They have grinds that will clear safely with no ptv clearence issues. Their stage 2 n/a cams are the best choice for the stock PI heads.
Call Nick at MHS, and decide for yourself. It was a real eye opener for me.
http://www.modularheadshop.com/Cams.htm
There's a lot of truth to that. Usually what needs to happen (with the stage 2's) is the intake centerline needs to be retarted (which costs power) or the pistons need to be notched.
