Driveshaft won't budge
I have bad luck with the easy parts of a task becoming difficult in themselves. I'm trying to remove the driveshaft on my '03 GT and I'm having trouble: I removed the four bolts that attach it to the pinion flange. My understanding is that after you remove the 4 bolts, the driveshaft should drop and you should be able to slide it out from the transmission. But, in my case, the four bolts are out and the shaft simply won't move. Am I missing something here?
Whew I got it. The PB Blaster probably helped overnight and then I placed a block of wood against the U-joint and gave it a few taps with a hammer and it dropped.
On to droppy the tranny lol. Probably a few questions coming from that step soon
Thanks!
Thanks!
You PB blasted it all night? Dude, I have done a TON of rears/trans swaps (Ford tech) and this is super common. Just tap the flange with a nice solid hammer a few times and be on your way. Im glad you got it but you just wasted a night of work lol
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
