Service engine light Rough Idle help plz
The Heated Oxygen Sensor (HO2S) is monitored for switching. The test fails when the HO2S does not switch due to circuit or fuel at or exceeding a calibrated limit
Possible Causes
Electrical:
# Short to VPWR in the harness or HO2S.
# Water in the harness connector.
# Open/shorted HO2S circuit.
# Corrosion or poor mating terminals and wiring.
# Damaged HO2S.
# Damaged PCM.
Fuel System:
# Excessive fuel pressure.
# Leaking/contaminated fuel injectors.
# Leaking fuel pressure regulator.
# Low fuel pressure or running out of fuel.
# Vapor recovery system.
Induction System:
# Air leaks after the MAF.
# Vacuum Leaks.
# PCV system.
# Improperly seated engine oil dipstick.
EGR System:
# Leaking gasket.
# Stuck EGR valve.
# Leaking diaphragm or EVR.
Base Engine:
# Oil overfill.
# Cam Timing.
# Cylinder compression.
# Exhaust leaks before or near the HO2S(s).
Possible Causes
Electrical:
# Damaged HO2S.
# Damaged PCM.
Fuel System:
Induction System:
# Vacuum Leaks.
# PCV system.
EGR System:
# Leaking gasket.
# Stuck EGR valve.
Base Engine:
# Oil overfill.
# Cam Timing.
