Loctite removal
another thing you can do is put a nut under the shift *** and once you have the *** facing the way you want it, tighten the nut under it up in to the shifter and it would hold it tight and its easy enough to remove, just loosen the nut and then the **** comes right off, i know a little late now but it might help some one.
jwog666
12-27-2021 08:09 PM
