Conv. Springs
Old 02-02-2010, 11:47 AM
spencwad
spencwad's Avatar
Default Conv. Springs
I've already made a post about this, but i was wondering if anyone has Eibach Sport-line springs on a 99-04 GT convertible. I'm DIEING to get these springs, but i dont to get the springs and have my car be not level.
Thanks
Spencer
spencwad is offline
Old 02-02-2010, 01:45 PM
IRSmart
IRSmart's Avatar
it's not that your car won't be level, but it will be crazy low. i have an 03 vert and i have the regular pro kit waiting to go on, and i'm hoping that it will be a modest drop. i just need to wait until summertime when i can afford some struts and complete the drop.
IRSmart is offline
Old 02-02-2010, 02:38 PM
spencwad
spencwad's Avatar
But its only a 138-140 lbs. difference between a hardtop and a vert. Any idea where all that extra weight is at?
spencwad is offline
Old 02-02-2010, 03:11 PM
IRSmart
IRSmart's Avatar
the convertible top motors, and the extra subframe connectors under the car and the engine to help stiffen the car up to compensate for the lack of a top.
IRSmart is offline
Old 02-02-2010, 08:33 PM
Z28KLR
Z28KLR's Avatar
Mods in sig.; I just went out and measured, and have about a hair over 2" gap (both front and rear) between the tires and wheelwell (fender lip, not the liner which is recessed into the well). Pro-Kit should give you about an extra 1/2", per mfr. advertisement. Also note that I'm running stock rims and tires. No problems with these springs in terms of bottoming out, harsh ride, etc. (running stock shocks and struts too). The only thing that sucks is that you have to cross most speed bumps at a 45* to avoid scraping your midpipe, but that's somewhat inherent with lowering your ride. I'm not sure where the extra weight for 'vert's comes from; the stock subframe connectors (which coupes also got I believe) are flimsy pos's that can't have a combined weight of more than 10lbs., top motor is about the same size and weight as a tall can of beer, and there's an x-shaped brace beneath the engine (which I think is unique to convertibles) that's basically a glorified strut tower brace. Just know that if you get these springs you absolutely will need C/C plates (MM comes highly recommended) and bumpsteer kit (shortened tie-rod ends). I also added urethane offset rack bushings when I did mine, but I'm not really sure how necessary they are since I don't see too many people talking about them.
Z28KLR is offline
Old 02-02-2010, 08:48 PM
spencwad
spencwad's Avatar
So you have a GT vert with those coils and its that low? Damn man. . .
Any chance you could load up some pics so I can can see what your car looks like?
spencwad is offline
Old 02-02-2010, 10:51 PM
Z28KLR
Z28KLR's Avatar
Stand by..... I gotta figure out how to post pics.
Z28KLR is offline
Old 02-02-2010, 11:19 PM
Z28KLR
Z28KLR's Avatar
Hope this helps, if you want some close-ups of anything let me know and I'll put them up.
Z28KLR is offline
Old 02-03-2010, 04:02 PM
spencwad
spencwad's Avatar
Damn man, I like that drop a lot. Thanks for loadin those up for me. Is that with iso's in or out?
spencwad is offline
Old 02-03-2010, 04:47 PM
Z28KLR
Z28KLR's Avatar
It's with iso's; I bought new iso's when I did the drop (Energy Suspension poly's)
Z28KLR is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Gene K
10-21-2015 11:37 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Conv. Springs
