trick flow heads
Old 02-13-2010, 01:05 AM
amusgrove81
amusgrove81's Avatar
Default trick flow heads
my pi heads keep shooting sparkplugs ! do the trick flow heads have a better design?
amusgrove81 is offline
Old 02-13-2010, 07:37 AM
mark a rittenhouse
mark a rittenhouse's Avatar
yes their design is to prevent that from happening.
mark a rittenhouse is offline
Old 02-13-2010, 07:41 AM
mark a rittenhouse
yes their design is to prevent that from happening. see artical muscule mustangs @ fast fords nov. issue page 84. they discuss all specs on their new head.
Old 02-14-2010, 09:39 AM
uin2it
uin2it's Avatar
Anyone seen any NA before/after dyno numbers with these heads!?
I know that Fox Lake is sellign these ported for a pretty hefty price....they really worth the money!?
uin2it is offline
Old 02-14-2010, 11:40 AM
ddmsgtr1
ddmsgtr1's Avatar
Depends on how much power your trying to make. Remember, in your case being a blower app. the more money you spend getting the engine itself to produce power, the less boost you have to run to get to your goal. If your goals are 400-500hp, no big deal, but if your looking for something like 750-800, that could be the difference between running being able to run pump gas or having to step up to race fuel.
ddmsgtr1 is offline
Old 02-14-2010, 10:54 PM
Ehmark
Ehmark's Avatar
Buy cobra heads they dont shoot plugs as often and they can be found on craigslit cheap. 2v <4v
Ehmark is offline
Old 02-15-2010, 02:07 AM
MU71L4710N
MU71L4710N's Avatar
theres alot more you need than just heads... if it was a cheap easy swapover there wouldnt be any 2v's on the road.
MU71L4710N is offline
Old 02-15-2010, 07:47 AM
nickmckinney
nickmckinney's Avatar
Get Timeserts installed on all eight cylinders, much cheaper than either option listed above and never pop a plug again.
nickmckinney is offline
Old 02-15-2010, 05:08 PM
amusgrove81
not true iv had a time-sert blow out!
Old 02-15-2010, 08:21 PM
ct_white_stang
ct_white_stang's Avatar
I wish I had the money for new heads. Now you have me questioning whether I should buy a blower or new heads and cams.
ct_white_stang is offline
Quick Reply: trick flow heads
