Which Differential Cover will Fit
I am looking at buying a new differential cover to replace my stock cover when I change the oil. American muscle have two but I am not sure which one will fit my stock Rear Differentials. Here are the links. All it says is one is 7.5 and other is 8.8 I am not sure which one I need to order. And why are these two covers for $29, why are they cheaper compare to others?
http://www.americanmuscle.com/mustan...gridle-75.html
and
http://www.americanmuscle.com/mustan...eargridle.html
and
They look like this:
Because what you ordered it basically nothing more than a chome version of your stock cover. The ones "over 100 bucks" are girdles which include two load bolts which screw against your differential's bearing ring caps, providing more support. They also feature separate drain and refill plugs which make future oil changes so much easier. Girdles also slightly increase your rear-end's oil capacity.
Gives you ease in changing oil and serves a function (more support)
This is the one I have http://cgi.ebay.com/ebaymotors/TA-PE...Q5fCarQ5fParts
All aftermarket units are decent
This is what i got http://cgi.ebay.com/ebaymotors/Ford-...item3a58804691. I did the best offer thing and got it for $81. It looks like the GMS which doesn't have the best track record for quality, but I can't see how bad you could screw up a girdle. There's really nothing there to fail!
