Passenger window won't roll up using the driver side swithc
Please help the passenger window won't roll up or down using the driver's side switch. I replaced the switch on the driver side and still nothing. Whats crazy is that its getting some power because you can press the passenger switch one way and press the driver side the opposite way and it will stop the passenger side so something is happening, but before i buy something else I was wondering if someone else has had this problem thanks.
Sheesh, somebody is raising the dead At least it appears that people are actually using the search feature.
From Chilton:
'If the same window works from one switch, but not the other, check the switch for continuity.
If the switch tests OK, check for a short or open in the circuit between the affected switch and the window motor.'
If you still can't get it, let me know if you have a coupe or a vert and I can look a little deeper.
From Chilton:
