RPM Question
Old 03-27-2010, 10:12 AM
B1DU5
B1DU5's Avatar
Default RPM Question
So Im trying to figure out what rear end i have in my 03 GT. What RPMs do you guys usually run doing 75 mph in 5th gear, and with what rear end? Thanks
B1DU5 is offline
Old 03-27-2010, 10:56 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Here's my "How Fast can I go in each gear?" calculator...
Quick answer (these all assume stock rear tire diameter):
with 3.27 (stock) gears 75 mph ≈ 2100 rpm
with 3.73 gears 75 mph ≈ 2400 rpm
with 4.10 gears 75 mph ≈ 2620 rpm
cliffyk is offline
Old 03-27-2010, 11:27 AM
SeanAndKate
SeanAndKate's Avatar
cliffy is it just me or does the "how fast can i go in each gear?" not work for the 4R70W? when I try to select it, it just stays on the last trans I had selected...
SeanAndKate is offline
Old 03-27-2010, 11:35 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Thank you for reminding me of that!
It had been on my to-do list but got shoved to the back burner--all fixed...
cliffyk is offline
Omgitsa88Stang
10-05-2015 07:33 AM
2015Ecoboost
09-17-2015 01:48 PM
Daddys Girls GTs
09-14-2015 08:46 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: RPM Question
