low rpm hesitation/stuttering
I have a 99 gt that sputters/misses when i give it more than 1/4 throttle at below 2000 rpm, I know this could probably be alot of things and I'll probably end up taking it to the shop next week, but any ideas? |
RE: low rpm hesitation/stuttering
Yeah, have your coil over plugs checked. I have a 99 GT and the intake bursted on me and it continously kept water on my spark plugs causing three of my COP to stop working (ie: three cylinders were not firing). Mine would shudder especially bad when it was in fifth gear and any gas was applied.
Hope this helps |
I had the dealership check it out, and they replaced one of the coils, but it didn't make a difference, and at $250 for one I would be hesitant to replace the other seven.
Try my post here: https://mustangforums.com/m_4511996/tm.htm
mine is in the shop right now, it does the same thing, but at idle... they just told me a few min ago, its my Idler control valve... so im having it replaced. its about a 350$ install parts+labor... i guess it got clogged/dirty. they said the used to be able to clean them, but they are made so small now that they cant.
ORIGINAL: joshafmil mine is in the shop right now, it does the same thing, but at idle... they just told me a few min ago, its my Idler control valve... so im having it replaced. its about a 350$ install parts+labor... i guess it got clogged/dirty. they said the used to be able to clean them, but they are made so small now that they cant. New IAC + Carb Cleaner in all thats like 60 bucks after tax...... |
