Fun with gears
Fun with gears
A couple weeks ago I had a set of 3.73 gears installed by a reputable shop, I got the car back and they whined like hell on deceleration, I called the shop, they asked me to bring the car to another local shop to get them re-done as he was going to be out of town. The new shop pulled them out checked everything over made a few shim adjustments and said everything looked good and put it back together, went for a ride and it whined even worse than before. He thought I probably needed a different set of gears altogether. So I drove the car home and made the shop come pick up the car. They had it for a few days put the new gears in and put over 150 miles on the car they called me today to pickup the car, we went for a ride and the gears were quiet. I brought the car home and immediately could smell gear oil. I looked around didn't see anything leaking on the ground. Decided I wanted to change my rear wheels, went to pull the lugs nuts and they were all loose, pulled the wheels off and inside of the rim is covered in gear oil both sides are leaking from the axle shaft seals, the differential cover is leaking as well. I can easily change the seals, but wondering what you guys would do?
Wow! You need to raise holy hell with that shop and make them fix it. Find out if they are part of the BBB and if they don't take care of it lodge a complaint. There is no reason the repair should be done right.
have them redo it. if you've been polite you should stop now. i would demand a whole new rear end at this point personally (or atleast a tear down and inspection of EVERYTHING). theres no telling what damage was done with no oil in your differential.
i would call the guy that referred you and see what he wants to do, but let him know you're pissed.
The shop is 50 miles from my house, I couldn't see wasting the time to drive it there. I actually had a new set of seals and bearings in my garage, I decided to just fix it myself. The rearend fluid was full when I pulled the cover so I don't think there is any damage. What pisses me off is I paid for the install kit which comes with axle seals and bearings, would have taken them an extra 10 minutes to replace, instead I had to rip it all apart myself.
KingRando
10-02-2015 08:06 AM
BeatnikFink
10-01-2015 08:00 PM
