4" crack in my Magna-flow Cats
Well I found the Exhaust leak. 4" crack on the bottom of the Cat. New Mid Pipe?(339.00) or can i get a exhaust shop to fix it cheaper?
welll if the cats cracked the cat may be breaking up (may or may not be a concern to you). if the cats breaking up they can weld in a replacement cat. if you don't care if its broken up they can just weld it shut.
If the cat is breaking up replace it ASAP. A faulty cat can cause a ton of issues including power loss, horrible MPG, stalling problems, and can also throw **** into your mufflers as well.
If it were me i would just get it looked at first and make sure nothing broke off and see if it can be welded and still function as it did before. If not i would just replace the converter itll save you a ton of money.
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
