WTF is this noise-video enclosed
Old 05-10-2010, 06:37 PM
JC316
JC316's Avatar
That is something seriously traumatic. Doesn't really sound like a rod to me. Have you checked the exhaust manifolds to make sure there isn't a big *** hole rusted in one? Also do a compression test, it would be rare not to smoke, but that sounds like a seriously cracked piston or a hole through it.
One other thing is the rod cap could have fallen off and that is the crank hitting the rod on every turn. Did you check to make sure the flywheel wasn't broken?
JC316 is offline
Old 05-12-2010, 02:27 AM
SmallFeesh
SmallFeesh's Avatar
When the car went in to the tranny shop they had the entire clutch/tranny out of it and running, so it couldnt be the flywheel, the car has been in vegas it's whole life, there isnt a rusted piece on it.
SmallFeesh is offline
Old 05-12-2010, 03:51 AM
JC316
JC316's Avatar
Flywheel makes more of a rattle anyway. If I had to call it, I would say a hole in the piston. Doesn't really make much sense without smoke, but that is the closest sound.
Have you tried unplugging an injector one at a time and see if it affects the sound?
JC316 is offline
Old 05-12-2010, 03:54 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
How did they start it with the transmission out?
cliffyk is offline
Old 05-12-2010, 12:43 PM
vinny69stang
vinny69stang's Avatar
I had the same noise in my 01 GT with built motor, and I pulled this out of number 2 cylinder....
vinny69stang is offline
Old 05-12-2010, 01:10 PM
devongarver
devongarver's Avatar
Have you pulled all the plugs yet to look at them? Or done a compression test? Start there before trying to part the thing out.
devongarver is offline
Old 05-13-2010, 01:57 AM
SmallFeesh
SmallFeesh's Avatar
Was the sparkplug loose or tight, and WTF happened?
The plugs are all tight, figured as long as they are all tight there wouldnt be a major problem there.
They put a mock bell housing on it to start it.
Old 05-14-2010, 12:09 AM
vinny69stang
The spark plug was tight. and idk what happened yet, haven't had time to pull the motor out. Hopefully at the most I only have to replace is valve, rocker, and/or piston
xdef00
02-27-2004 03:18 AM
Quick Reply: WTF is this noise-video enclosed
