QUESTIONS
#21
Also...everyones been telling me to go with a H-pipe...anyone know anything about or have the off road prochamber mid pipes? supposedly its supposed to "outflow" h-pipe and x-pipes and deepen the exhaust note..
any input guys?
any input guys?
#23
Can you explain why the PC will flow better? From my way of thinking it would flow less than than a o/r h or x, due to the larger box or chamber if you will. I could see how it might create more back pressure (which could benefit the mid range a bit more) due to it's design, but it doesn't make sense to me how the total flow would be better.
#24
Listen man if you already have an intake and plenum as I see from your sig. I'd get a throttle body for sure. Obviously you'll notice a bigger difference from headers but you can get a decent throttle body for around $100 and some change and throw it on your self. However if you get L/T's you need to get a shorty x-pipe or h-pipe right away. Which all together will cost you 2 to 3 times as much. For around $200 I'd get t/b and pulley's if you look around hard enough you can probably find both for around $200 for everything. Yeah you're not going to see huge gains but you will notice a difference and it's something you'll want to do down the road anyway. Plus t/b is a nice addition to plenum and intake!
#25
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
