FI cleaner made my stang louder.
I used the STP Fuel Injector cleaner made with Jet Fuel on my engine. For some reason it has made my exhaust louder. The car does have a little more pep tho and gas milelage is only very slightly better. I was wondering if the sound increase is normal or should I get my engine checked out. BTW my car has about 58,000 miles on it.
RE: FI cleaner made my stang louder.
It cleaned all the carbon **** off the valves, which means just a little bit more air coming in and out the engine. So, I suppose it would be normal to hear a slight increase in noise. Did you run it through the tank or vacuum lines?
I ran it thru the tank when I was filling it up with gas. I heard that for a few dollars it would help my engine since people usually put higher octane gas in mustangs thinking it helps the engine. Since my car was used with 56,000 miles I said why not.
ORIGINAL: marcuslee842
Oh yeah, if it cleans off the cabon and other stuff where does it go? It dosen't settle in the engine does it?
ORIGINAL: 02StanGT
Out the exhaust. If you suck it through a vacuum line (making it more concentrated than when you mix it with your fuel), your car will actually start to smoke. The smoke is all that bad **** coming out at once, where as through the gas tank it is cleaning it a little at a time. Which is why you don't see any smoke.
