Old 10-08-2015, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Stripped motor mount nut
Old 04-28-2010, 05:50 PM
jvog
jvog's Avatar
Default Stripped motor mount nut
So yea theres always something going wrong lol. When I went to take the motor mount off I noticed one of the nuts/studs was a little rounded (I didn't remember it being like this when I put it on last time). I tried getting it off and it just kept getting worse and worse so now its pretty much effed. I see two options, leave it on the way it is becaues I really don't need to take it off, or get a reverse drill bit and try drilling it into the end of the stud and get it out that way. The problem with the first idea is that if I ever need to replace the mount with the motor in the car IDK how I'd get it off. The problem with the second idea is that its gonna be kinda hard to get enough torque using a reverse drill bit to get a motor mount stud out. What do ya guys think?
jvog is offline
Old 04-28-2010, 06:10 PM
smythge
smythge's Avatar
Did you strip the bolt, or round the head of the nut?
smythge is offline
Old 04-28-2010, 06:21 PM
jvog
jvog's Avatar
The nut. The nut is attached to the stud in the middle
jvog is offline
Old 04-28-2010, 08:25 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I have a set of these, however to be honest they don't really work all that well on badly rounded nuts...
Your best bet might be to not worry about it for now and when it does have to come off someone good with a torch or plasma cutter will be able to get it off easily.
cliffyk is offline
Old 04-28-2010, 08:34 PM
kenv
kenv's Avatar
Well, I always say, if it ain`t broke, don`t fix it. If its tight & you have no reason to take it off- just leave it alone.
kenv is offline
Old 04-28-2010, 09:00 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
My problem is always that knowing it's there bugs the crap out of me...
cliffyk is offline
Old 04-28-2010, 09:31 PM
jvog
jvog's Avatar
Yea I have a set of those too, but since its attached to the stud in the middle (IDK what you call a stud with a nut attached to it, its like a bolt/stud lol) I would need a deep one of those and I haven't seen any.
I thought about having someone torch it off, but my block is aluminum and seeing as its right up against the block I can't imagine that turning out well.
jvog is offline
Old 04-28-2010, 09:42 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
A small torch tip, or a plasma cutter, in the hands of someone that knows what they are doing will be very brief and localised heat. Aluminum conducts heat so well that a big block of it is a bìtch to heat up...
cliffyk is offline
Old 04-28-2010, 10:03 PM
jvog
jvog's Avatar
Oh alrighty. So the only problem with me leaving it on is if I ever need to replace the mount the motor will have to come out to do so. No way a plasma cutter is gettin in there
jvog is offline
Old 04-28-2010, 10:13 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If you can get a wrench on it a small cutting torch tip, or hand-held plasma torch, can get to it...
cliffyk is offline
Quick Reply: Stripped motor mount nut
