Heads and Cams without forged internals?
Wondering if it would be a waste to only bolt on some ported 3 angle job pi heads with some nasty cams/boosted without doing forged internals. Plan was to get forged internals but I am not too sure if I can afford it. I want to finish my suspension and do the drivetrain as well with a tko 600. Not sure if I can afford all of this and was wondering if It would be dumb to bolt on heads with stock internals. Thanks for the help guys
RE: Heads and Cams without forged internals?
Depends on how much boost you want to run, heads and cams are always good for more power but on a FI set up like yours it just means you have to run less boost and have a more conservatuve tune. Talk to MDvaldosta about what he has done, I am sure he can point you in the right direction.
Thanks for the help guys, but even with the dished pistons it won't bring the compression down enough for a boost friendly application with the PI heads? I am just gonna keep the boost low for now then turn it up when I get the suspension and drivetrain done? Thanks!
