Attempting hydraulic lash adjusters removal and installation.
Well the noise coming from my engine is apparently valve chatter, so I'm going to attempt the fix myself has anyone done this before or have any tips? Any help will be appreciated....
It's easy. Just pop the valve cover, set the cam lobe where the pointed end is up, then hook a screwdriver on the rocker arm on the lash adjuster end and pop it off. Put the new one in and reverse the procedure.
having trouble getting driver side valve cover off, gonna pick it up again tomorrow. I looked up the problem im having with the booster being in the way i guess im just doing something wrong, gonna check out the motor mount tomorrow...
There are two tensioners, so it could be coming from the drivers side. It's not all that hard. Just do yourself a favor and take the radiator fan out before you do it.
