Service Engine Soon
Old 08-04-2005, 07:04 PM
OUZBnd
OUZBnd's Avatar
Default Service Engine Soon
The service engine soon light keeps getting tripped. I'll reset the computer and it might go for 2-3 weeks, or it might go for a few days, but it keeps coming back on. The codes Im getting are "lean bank 2" and "air metering device" I've cleaned the mass air but it came back on a couple weeks later. any suggestions?
OUZBnd is offline
Old 08-04-2005, 07:22 PM
98UAGT
98UAGT's Avatar
Default RE: Service Engine Soon
Didn't you just put long tubes and a new mid-pipe on? If I am remembering the right mods for you, you are probably just moving too much air for your fuel amount. Get a tuner and bump up your a/f ratio and fuel curve, or get a dyno tune.
98UAGT is offline
Old 08-04-2005, 07:31 PM
OUZBnd
OUZBnd's Avatar
i did, but the problem started before the install..
OUZBnd is offline
Old 08-04-2005, 07:34 PM
02StanGT
02StanGT's Avatar
The air metering device of course your MAF you may need to clean it or replace it. The lean bank 2 is drivers side o2 sensors reading wrong might check into replacing or cleaning those as well.
02StanGT is offline
Old 08-04-2005, 11:56 PM
04BlueGT
04BlueGT's Avatar
^Um, yep. My guess is O2s like he said^
04BlueGT is offline
Old 08-05-2005, 01:19 PM
OUZBnd
OUZBnd's Avatar
should I just try and replace both driver side o2's, or start with the easiest/cheapest. BTW, how much do those run? As far as the MAF, i've cleaned it once. I hate to replace it because it's a Pro-M, but we'll see what happens i guess
OUZBnd is offline
Old 08-05-2005, 11:22 PM
02StanGT
02StanGT's Avatar
ORIGINAL: OUZBnd
Do your rear one's have MILs on them?
02StanGT is offline
Old 08-06-2005, 03:49 PM
OUZBnd
OUZBnd's Avatar
Yes, the rear have MIL's. The problem also started before the longtubes were installed. Logically, i should assume its the front since the rear have the MIL's, but I'm not clear on exactly how the MIL's work.
OUZBnd is offline
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Service Engine Soon
