Pilot Bearing
06-02-2010, 08:10 PM
so you never answered the question what is the "bread method"
06-02-2010, 08:46 PM
Quote:
Originally Posted by
BraMas
yeah he did...post #3. its the same thing as the grease technique, but i've never heard it called that.
06-03-2010, 01:51 AM
06-03-2010, 02:02 AM
06-03-2010, 05:42 AM
Chupacabra
Mine was a PITA too, grease trick didn't work, slide hammer didn't work. Finally i got a piliot bearing puller but the jaws wouldnt fit untill i mangled out the inner race lol.
06-03-2010, 08:47 AM
Well clutch and tranny went in like butter.
06-03-2010, 06:20 PM
Took it for a drive and it shifts fine but it has a vibration that I think is coming from fly wheel area. What do you think ?
06-03-2010, 06:56 PM
TECH SAVANT
Could be...
Did you clean the crankshaft flange well before mounting the flywheel?
Did you torque the f/w mounting bolts correctly?
Were the locating dowels on the flywheel,l for the pressure plate assembly, straight and fully seated?
06-04-2010, 07:43 AM
cliffyk
Could be...
I took my time and even cleaned the back side of the flywheel. I torqued the bolts evenly to 60ft lbs.
06-08-2010, 02:22 PM
Is the throw out bearing considered self centering. The reason I ask I have to pull the tranny out again and just in case I need to get a new one I anted to know?
