The max width i can go on a stock rim..
Hey guys.. Im looking to pick up some BFG Et streets within the next few days and i was wondering wuts the max i can go on my stock rim. Right now i have 17x45x245 on there, can i go any bigger then 245 or is that the max i can go?
RE: The max width i can go on a stock rim..
ORIGINAL: redass02gt
255 will also fit ok, bigger than that is iffy.
He's absolutely right.
Your going to have a LOT of people come in here and say 275's will fit just fine, only bulging out from the rims a bit. Well, do your homework. Every single tire manufacturer lists that 255's are the max tire that will fit on an 8" rim width. Other tires will fit, but it's not recommended. Squeezing a wider tire on a too-narrow rim will alter the handling charachteristics of the vehicle a bit. Your essentially changing the flex point of the tire.
A larger tire WILL fit, and everyone will say they have been doing it for years and it's worked just fine. This may be the case, but your handling will be that much better with a tire designed to fit on the recommended rim width. If you want to go larger yet to a 275 or so, upgrade to a 9" wide rim.
Put 275/40/17's on the rear and 255/40/17's in the front. It will be a little wider in the front plus have a nicer looking low profile. And the 275/40/17 will keep your speedo exactly right, as well as they fit perfectly.
well right now im running 245X45X17 on there all around, front and back im looking to get some BFG et Streets Wut should i throw on there for the rear?
ORIGINAL: idriveamustang
Pick up some BFG KDW's for the front.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
