Steeda Sport Springs HELP!!!
Old 08-07-2005, 03:40 PM
GrayGhost01GT
GrayGhost01GT's Avatar
Default Steeda Sport Springs HELP!!!
hey guys whats up I have installed the Steeda Sport Springs and the Steeda X2 Ball joints. Should I get new Caster and Chamber plates so my Tires wont wear bad Has anyone ever used these springs will I be ok I got the Stock Shocks and Struts. Please Help!
GrayGhost01GT is offline
Old 08-07-2005, 03:44 PM
04BlueGT
04BlueGT's Avatar
Default RE: Steeda Sport Springs HELP!!!
Up to 2 inches, the stock shocks and struts are fine. BUT, you need bumpsteer kit. Steeda states that you need them if you use the ball joints. Or, C&C plates. Or, offset rack bushings. You gotta do something for the steering geometry or get used to buying new tires.
Good luck.
04BlueGT is offline
Old 08-07-2005, 04:46 PM
GrayGhost01GT
Really Uhhh Crap I just bought a Bassani Aft so im tight for money I just dropped it like 1 inch and a 1 3/4 in the rear uh I used the X2 Ball joints. do I really still need them how much tire wear am I looking at? How much money am I lookeing at for the bumpsteer install? and ideas
Old 08-07-2005, 05:10 PM
04BlueGT
04BlueGT's Avatar
You can get the offset rack bushing for about $45 from Ford (et al) and install them yourself with a jack and stands. I would budget two hours, since you've never done it. Neither have I, but my buddy is helping me do it on the 27th.
As for tire wear, the inside edges will take the brunt of it. You should be okay on the short term, but I'd do it as quickly as possible. Not only will the tires wear, but hitting bumps can cause your front to hop around a little ergo, 'bumpsteer'.
Good luck. I'll post my results with the offsets after we get them done on the 27th. I think you can wait that long safely, if you want. It looks to be straight forward and simple.
04BlueGT is offline
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
Quick Reply: Steeda Sport Springs HELP!!!
