so i am running comp cams xe270ah on my 03 gt and i was wondering if knows if this will be a ok camshaft to run with a supercharged application? if not what would be a good cam to run? what kind of lobe sep should i be looking for on the cam shaft?
Is their any issues with the compression with supercharging vs turbo charging? Usually in turbo they run around 9.5:1 The 03 GT runs around 11:1 right? Does it produce "ping" detonation?
the 2 guys i recall very well were from a different forum. one guy had a built shortblock 5.4, 8.5to1 comp., stock heads, 270 comp cams, eaton s/c @ 22psi. it was either 540 or 580 rwhp. the other guy had a stock 4.6, vortech, unknown to me psi, comp 270s. 425-430 rwhp
