how can i fix this? where does it locate?? i realy dont understand why does the car shift fine when its cold nut after like 5 minutes the problem comes back !!
Yes , and I did went to another shop and the open the trany piece by piece and put it to gether again and they said evry thing seems ok , however I was checking the diablo handheld in the peremeters option , in the shift pressure , theres is the part throttle shift firmness 1-2 , 2-3 , 3-4 , the 2-3 is set to 25 psi ! While all other sets is stock , so I adjust it to stock but also with no difference :s. And also there is the WOT shift firmness all set stock
This problem happens when the car and oil heats up ! Did I mention that I have a transmission cooler?? Could it be from the cooler??I mean that there's damage in the cooler
