differential and manual tranny fluid change Redline?
Ok I was looking at a Chilton's manual and it said the replace the rear differential fluid and manual tranny fluid every 60k
The book said use Automatic tranny fluid in the manual??? Is that right?
I was going to put in Redline, but I'm not sure what to put in it now. It's an 03 GTI and I believe the tranny is a 3650
Anybody have any input on the types and grades for diff and tranny?
Thanks
SS33
Thanks
SS33
many here find mobil 1 ATF (synthetic) to work the best for the 3650, as does tremec since thats what they recommend. also, fill up to only 3.2 quarts, not the originally recommended 4, as it will cause shifting problems
edit: do NOT put ATF in the differential. it has its own fluid. i would suggest motorcraft and a bottle of friction modifier
Synthetic sounds good. I've been sold on synthetics since I had a turbo car and saw the differences. Diff gets gear oil but what is the friction modifier your talking about?
BTW thanks for everyone's input!
SS33
friction modifier is an additive that helps keep the clutch packs from binding in the diff. someone could probably give you a better explanation, but thats the best i could come up with without a viable source. you can buy it from your local ford dealership for about $10
Draining the tranny is very easy, but unless you have a pump, filling can be a pain. I recently discovered an "easier" way to fill the 3650 (and possibly others). I had my shifter out when I pulled the tranny for the clutch sway, so I added the fluid through the top while the shifter was out. Very easy and no mess at all. Just something to think about.
Just make a "beer bong" but then it becomes a Tranny filler bong" ahah And not such a large dia. tube. Fill it from inside the car routing it down beside the tranny and maybe have someone get under the car to make sure it does not come out of the fill hole. Then pour away.
The diff. is not the same case. I believe you need the pump style bottles as there is no easy way to get a funnel above the fill hole and have gravity do its thing.
