engine chatter
I listened to it using my studio headphones and the good news is that I definitely did not hear any pinging, which is what I thought you were describing as "chatter".
What type of blower do your have, centrifugal or twin-screw?
It did sound like the engine was misfiring--though I am not really certain I heard the noise to which you refer, is it low or high pitched? Is there a loss of power?
I would pull the plugs and check them, and do a compression check while they were out.
Aren't exhaust leaks funny things? Sometimes you could swear it's some sort of dark mechanical problem...
It's not good, and will of course only get worse if not tended to--it may also cause the O2 sensor readings on that bank report lean--which is better than having it report rich.
This will cost you some fuel economy in closed loop mode, may throw a code if the STFT maxes out, and once the LTFTs get relearned it could make that bank run rich in open loop mode.
It would drive me crazy--I'd have to fix it...
I have no real notion of the cost, however I would be prepared for 1/2 or more of what it cost to have them installed--depending on whether they have to raise the engine/drop the A-frame. There's not a whole lot of room to work down there...
I wish I would have seen this thread earlier...I knew after cliff said it didnt sound like pinging(I can't listen to vids here at work) that it was an exhaust leak for sure. I had the same issue in my truck before. Well, atleast you got it figured out!
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
