idle screw throttle body thingy
RE: idle screw throttle body thingy
You may not wanna use that screw to adjust the idle unless you know what you are doing.
You have to unplug the IAC bypass connector, adjust the idle to 500-600 rpms WITH it unplugged and then plug it back in and the idle should be at or about 900 steady. Dont just turn the screw. When you unplug the connector the car will either idle up or idle down and almost die. Adjust it from there.
I think if you back that thing off too far then you'll rely on your TB throat and carbon deposits to set the butterfly to home. If you bump it too far in, you'll keep your butterfly ajar and have the equivalent of a vaccuum leak. You ECU will try to compensate via the IAC if you haven't restricted it or unplugged it. I have my IAC restricted to lessen the throttle hang syndrome.
ORIGINAL: jishead
