Cutting rear springs
Smitty you cut the total opposite ends... The smaller part of the bottom of the rear spring is like that for a reason. You were supposed to cut the top of the rear so that the bottom would seat on the control arm correctly.
As for cutting the top of the front springs, you were supposed to cut the bottom bc that is the part that just lays in the control arm. The top needs to be flat for the front springs...
I guess it's fine as long as it rides well..
09-08-2015 11:50 AM
