Trouble installing rear brakes
This isn't something you push in. The rear piston has to be turned. It has two notches that are "V" shaped and the manual said you can use a needlenose plyers to turn it or a brake piston tool but neither work. It looks like it might be all the way in though now that I think about it. There is only about a 1/6 of an inch sticking out. I think I may let my local shop worry about it. I tried putting on the new pads and getting the caliper back on but no go. It won't go over the new pads.
Ah you called me a "********" and a "douche bad" all in the same post. Thank you I'll take it as a compliment. The point is if you don't know don't post
OP I wouldn't sand the brakes down you need to make sure the brakes are working properly. What I do when they are being stubborn I try spinning it one way and than spin it the other way eventually it will go in
I have done allot of brakes in my life and have never had to sand down new ones to get them to fit. The only time I have had trouble is when I thought the piston was all the way in and it wasn't. If the piston is not all the way in you will not get the caliper bolts back in
that was the only time i had to do it, the pads came from ebay so that might be why, i even had my freind who is a mechanic help me and he said it was the only option i had with out getting new pads,it wasnt much to sand
exactly, that's why I asked if they were cheapo pads or out of spec...which they obviously were. No harm no foul, just sayin, in normal oem replacement, sanding is not in the procedure lol
Fast-Hands
08-19-2015 06:54 AM
