idle issue???
Old 08-11-2010, 07:50 PM
Paulejr13
Banned
Paulejr13's Avatar
Default idle issue???
hey guys, i have a tune on my car, no changes exept caned tune for xpipe catback gears and cai
if im in 1st gear or n e gear its fine, but when im in neutral and lets say i rev to 3500 it drops to 1500 and hold for a few seconds then drops to idle, this happens in neutral or when i have the clutch pedal all the was down and the rpm are dropping, it doesnt dropp straight to idle
it drops to 1500 holds then drops
Paulejr13 is offline
Old 08-11-2010, 08:57 PM
Paulejr13
Banned
Paulejr13's Avatar
bumpp
Old 08-11-2010, 09:04 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's normal for it to hang for a bit as the PCM has an electronic "dashpot" function to prevent the engine from stalling when the throttle is cut.
However if it is hanging for few seconds as you describe then the IAC is sticking and needs to be replaced...
cliffyk is offline
Old 08-11-2010, 09:18 PM
Paulejr13
Banned
Paulejr13's Avatar
maybe 2 seconds? and it only does it wirh new tune not on stock tune, should i bump my idle up a little or is this just normall cause its anoying as ****. i go to give a rev, and then its sits for a sec then drops it sounds like doodieee
Old 08-11-2010, 09:48 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Did you turn off the traction control in the tune?
Send me your stock tune (from the Original Files folder), and the tune that is acting up--I will compare them side-by-side with Delta Force and see what's up...
cliffyk@paladinmicro.com
cliffyk is offline
2007StangV6
01-28-2016 06:09 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idle issue???
