Dome Light and Driver Window
Old 08-25-2010, 01:30 PM
bryantwalley
Default Dome Light and Driver Window
Hey All,
I got something wierd going on. If I use my key remote to unlock the car, the dome light gets stuck on. If I drive for a while 20-30 miles I will hear a tone and the light will go off.
I am also having problems with the driver window rolling down. Seems at random times when I press the switch I will hear the click under the dash but the window will do nothing. Then out of the blue it will work fine.
The click seems to come from a black box between the fuse box and the fender wall but I can not be sure.
Any body have any ideas on what is going on with this?
Mustang is a 2004 GT
bryantwalley is offline
Old 08-25-2010, 02:08 PM
TEXASx2000xMUSTANGx
TEXASx2000xMUSTANGx's Avatar
i have the exact same problem with my 2000 GT so if you find out wahts wrong please let me know!
TEXASx2000xMUSTANGx is offline
Old 08-25-2010, 09:06 PM
lizzyfan
Underboss
lizzyfan's Avatar
Dome light staying on is from your door switch going bad
Common Ford issue
lizzyfan is offline
Old 08-26-2010, 01:15 PM
stangladesh
stangladesh's Avatar
had that dome light issue and found out that the wire had a connection problem. the tech who put in my alarm had cut it and tried to splice it back together. i got under there and put in a better splice. i think that wire is purple. if i think about it this evening i will take a pic of it or it could be a door switch like lizzy fan stated. the window issue could be a shotty motor or relay.
stangladesh is offline
Old 08-26-2010, 01:34 PM
devongarver
devongarver's Avatar
Originally Posted by bryantwalley View Post
Hey All,
For the door, this is super common, a search will reveal a bazillion threads on it. It is the motor. Slam the door while holding the switch in up or down, whichever direction you are trying to go, and it will jar the motor just enough usually to kick start it so to speak.
For the dome light...does it do it ONLY when the remote has been used to unlock, or does it do it every time you get in the car?
devongarver is offline
Old 08-26-2010, 02:12 PM
jjandascog
+1 on the doem light switch being bad, as said it is a common problem. It is located in the latch of the door, not hard to change.
The window sounds like a motor going out, replace motor
jjandascog is offline
Old 08-26-2010, 07:23 PM
Kong1965
Kong1965's Avatar
+2 on the dome light switch. Typical Ford problem. I've done swaps X3 on F150s.
With the window, I also find it to be a switch problem. The rocker switches can fail, and without replacement you will never be able to solve the problem. Again easy to replace. Try some contact cleaner first.
Kong1965 is offline
Nick Oliver
10-17-2018 04:22 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
zachary1988
09-04-2015 03:04 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Dome Light and Driver Window
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
