Pilot bearing install question, need answer asap
Neither have bearings because I installed the second and when I removed it because it didnt fit the bearing came out. The one that came out is identical to the one on AM for the 5.0 and the one I removed, the one on the second is identical to the one listed on AM for my car and the one Ford says is for it
I understand what you are saying and I agree with uberstang1. As long as the bearing fits flush, it should be fine. Don't worry about the extra thickness of the bearing lip. If your still uneasy, see if you can get one of each (5.0 and 4.6) pilot bearings from a local parts store. Test fit each bearing on your transmission shaft. There shouldn't be any play in the bearing and the shaft. If one fits perfect and the other has play, then you know whats up. Keep the one that fits and return the other.
If they both go in the same amount of distance and one just sticks out because of a larger lip it probably simply means thats how it is. The new lip is thicker, and the reason the new bearing wont go in any farther is probably because its already in all the way. The pilot bearing doesnt "need" to see flush with the crankshaft as long as it is in all the way. I just did a clutch in my car about a year and a half ago but can't remember what my pilot bearing looked like installed. If you're looking for something else I read in MMFF about a bushing that Ram makes to replace the pilot bearing, its was a kevlar/nylon construction and supposed to be superior compared the a standard piliot bearing.
Jskeezy84
09-08-2015 01:40 AM
