2004 Mustang GT Mild idle Flutter
Wait--at 4500 miles (which have been useful info in the first) it is highly unlikely that the IAC has worn enough to be causing the noise.
Are you 100% sure that what you are hearing is not just plain ol' intake noise?
Also, by "...idle will flutter after it has warmed..." do you mean that the idle is a tiny bit "lumpy"-if so then there's nothing wrong these engines can have a slight "rolling/uneven" idle, mine has been that way since I got it with 30k miles.
The intake noise is just uneven. You can see a small dip in the rpm gauge
If it is just a tiny bit then it's normal for these engines, part of the PI (Performance Improvement) changes to the 4.6L 2V introduced in 1999 was higher lift and more aggressive cams--they can be a little bit "lumpy" at idle.
2000, 2004mustangs, 2v, aggressive, dip, flutter, fluttering, gt, iac, idle, intake, lower, mild, mods, mustang
