RE: need more speed
ORIGINAL: bumpinwheels95 that guy is full of bs i have 373 gears n flow master n i raped a 350z well by one car length n if u havbe all those mods vs that guys mods ud rape him he had to have had more but id think about boring out ur pistons dont go to much or ul crack it while ur rtacing n then its big $$$$$$$$$$$$$$$$$$$$ I believe 04-05 350z's come with 300hp, a slight upgrade over the early 350z. Also, you modified your exhaust, but what have you done to your throttle body and plenum? You should seriously consider upgrading and getting a dyno tune, rather than your diablo tune. |
RE: need more speed
ORIGINAL: Dan04COBRA ORIGINAL: bumpinwheels95 that guy is full of bs i have 373 gears n flow master n i raped a 350z well by one car length n if u havbe all those mods vs that guys mods ud rape him he had to have had more but id think about boring out ur pistons dont go to much or ul crack it while ur rtacing n then its big $$$$$$$$$$$$$$$$$$$$ I believe 04-05 350z's come with 300hp, a slight upgrade over the early 350z. Also, you modified your exhaust, but what have you done to your throttle body and plenum? You should seriously consider upgrading and getting a dyno tune, rather than your diablo tune. |
RE: need more speed
I think his comment was more about beating a 350Z with mufflers and gears only. I'm not buying it either. The Z puts almost as much HP to the back tires stock as an PI'd Mustang has at the flywheel.
No comment on the mods suggested, but plenty on the grammar. [:'(] |
