Gasket: Oil Filter Mount to Engine Block
2010 Blue Ball Award Recipient
I got the gasket a few months back and have been putting it off.
Tomorrow is my first day off in a few weeks so I'm thinking about replacing it tomorrow.
Anyone had to do this before?
How long might it take?
Even a quick write up?
I know I have to drain the oil and remove the radiator lines. Anything else?
I'm not sure if its the same on the 2v and 4v, but when my oil cooler started to leak on my car when I was doing my SC install ford told me there was no replacement gasket for it and I had to buy a new unit with a pre-installed o-ring type seal. But if you replacing it all you really need to do is drain the coolant no need to drain the oil because the majority of it is sitting in the pan.
Am I missing something here? The very first line of the OP's message is:
"I got the gasket a few months back and have been putting it off."
Also, you need to drain the coolant as well (and can get by without draining the oil if the car has been sitting for several hours/overnight)--the bolts should be torqued to 18lb/ft per the shop manual...
