Modification to the air flow
i have aquestion, i just midified the air flow system and installed a Trick Flow® High-Flow Upper Plenums for Ford 4.6L 2V and the "service engine soon" light turned onn, but aparently all of the sensors are in good shape
i want to know if this is a common error or there is something wrong with the engine???
You need to have the codes read (any FLAPS [Favourite Local Auto Parts Store] will do this)--let us know what they are, and look them up here, then the problem can be resolved...
The shop manual lists the possible causes in descending order of probability; with the PCM being last on the list:
- IAC circuit short to GND
- Damaged IAC valve
- IAC valve stuck open
- Vacuum leaks
- Failed EVAP system
- Damaged PCM
That the "calibration" (tune) is causing the problem is a very remote possibility.
Double check all of the connections (electrical and others) that you disturbed when you swapped out the plenum. Pay close attention to the EGR valve/plenum gasket--they often crack and leak if reused...
It wouldn't make that much of a difference the computer would be able to adjust like it is supposed. You most likely didn't put it back together right. Did u connect the hose on the back of the plenum? Will it run fine at engine speed? Mine did that for like a day and then i realized i was dumb and missed the connection.
Not clearing the KAM would not cause it to throw the IAC malfunction code; something got damaged or put back together incorrectly...
well i disconnected the battery cable for around 4 to 5 minutes and then it cleared off, but again in a while the light turns back on.
this is getting me preocupied since i dont want the engine to be damaged or the ecu.
All of the comments u guys are posting, are really helping me allot, Thnks...
