TPS sensor go bad or what?
Old 10-21-2010, 11:06 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Originally Posted by deviousgt View Post
TPS? how often should the battery be changed?
TPS = Throttle Position Sensor
Battery = when it fails to hold a charge and/or cannot supply sufficient current to start the engine. This is generally because of a phenomenon called sulfation in which sulphur in the electrolyte drops out of solution and coats the lead plates--effectively building up an insulation barrier that reduces electron flow.
It is caused by:
  • Not maintaining a proper charge (not charging sufficiently often, as in cars that are not driven regularly);
  • Deep-discharging a starting duty battery, or not deep-discharging a deep-cycle battery;
  • Not maintaining electrolyte level;
  • Incorrect charging (failed generator/voltage regulator, cheap "trickle" chargers, or higher amperage non-regulated chargers);
and a bunch of other reasons--Google it...
cliffyk is offline
Old 10-27-2010, 05:49 PM
MU71L4710N
update incase this helps anyone out:
it was the fuel pump. which slightly baffles me because fuel pumps are usually yay or nay, not "kind of working".
MU71L4710N is offline
Old 10-28-2010, 05:26 AM
uberstang1
Chupacabra
uberstang1's Avatar
Interesting outcome, the fuel pump probably would of been the last thing i metered with those symptoms. Well glad its fixed.
uberstang1 is offline
Old 10-28-2010, 05:34 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Good to hear it fixed up.
As fuel pumps age their output drops off however usually it's a gradual thing, not a brickwall that pops up all of a sudden--good info to file away for future reference...
cliffyk is offline
jwog666
01-07-2018 07:16 AM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
mrtrodonet
09-29-2015 11:13 AM
Quick Reply: TPS sensor go bad or what?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
