Why GT's Run on Regular?
Old 08-16-2005, 02:33 AM
GrayGhost01GT
GrayGhost01GT's Avatar
Default Why GT's Run on Regular?
Hey guys, whats up I was looking at a speedodometer and it was on a 04 Mach 1 why does the Mach reaquire Preimum Fuel? It says Preimum Fuel Only but why do our GT's Run on Reguler I rarely Run Regular in my GT but I still feel a difference seems like my GT is Slugish on Regluar So i always put in Super or Preimum Why dont the Machs take Regular?
GrayGhost01GT is offline
Old 08-16-2005, 02:39 AM
96mustanggt46
96mustanggt46's Avatar
Default RE: Why GT's Run on Regular?
Mach 1's have higher compression than GT's
96mustanggt46 is offline
Old 08-16-2005, 02:42 AM
redass02gt
EXTREME Moderation
redass02gt's Avatar
you shouldn't waste your money on the premium if you need regular. you don't gain anything.
redass02gt is offline
Old 08-16-2005, 02:46 AM
eclipsegt
eclipsegt's Avatar
my cobra says premium only
eclipsegt is offline
Old 08-16-2005, 02:52 AM
02StanGT
02StanGT's Avatar
ORIGINAL: 96mustanggt46
That's right.
02StanGT is offline
Old 08-16-2005, 03:54 AM
ZW99GT
ZW99GT's Avatar
Its all in ur head. You dont feel any difference in fuels unless you put in fuel from a raceway or fuelmart or other no namebrand fuels. Exxon shell amaco ect 87 will burn PERFECT in ur gt. Thats why your manual reccomends it. Would ford reccomend 87 if i didnt run right? I think not.It actually leaves deposits in your engine if your compression isnt high enough to burn higher octane.
ZW99GT is offline
Old 08-16-2005, 08:04 AM
04BlueGT
04BlueGT's Avatar
Higher compression N/A motors (Mach 1) and forced air motors (Cobra) require higher octane fuel to avoid detonation. If you're not familiar with the term, detonation is that wonderful event that puts holes in pistons (if you're lucky) or ventilates your block with a connecting rod. Of course, neither one is a good thing.
Ford engineered the GT to run on 87 for a reason: it's cheaper. You can now buy your GT, pay less at the pump, and feel good about the money you saved. Quite clever sales gimmick, really.
You can run higher octane fuels in the GT, but you get no gains from it. However, you may build up residue on the valves and exhaust runners. I believe it is carbon build up. Correct me if I'm wrong folks.
If you advance the timing, you'll want 91/93 octane in your pony to avoid detonation. I know you can advance the timing to 14 on a N/A car, but is that on 87 or 93 octane? I never read anything about the grade of fuel in the articles.
04BlueGT is offline
Old 08-16-2005, 08:29 AM
IWinULose
IWinULose's Avatar
ORIGINAL: 04BlueGT
If you advance your timing, you had better be runnin premium. If not - it's gonna get nasty.
IWinULose is offline
Old 08-16-2005, 10:39 AM
Chopper
Chopper's Avatar
You can advance the timing on a N/A GT by at least 3*without lighting a CEL or any detonation and still run 87 octane.You can also pick up about 2 mpg by using a Steeda timing adjuster.Personal experience.
Chopper is offline
Old 08-16-2005, 11:58 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
ORIGINAL: ZW99GT
That won't make any difference unless you have advanced timing or bump your compression
Dan04COBRA is offline
Quick Reply: Why GT's Run on Regular?
