Buying my gears need advice
Old 08-17-2005, 04:12 PM
HARD DRIVER
HARD DRIVER's Avatar
Default Buying my gears need advice
Alright fellows, I've got my credit card ready and I'm ab out to order my gears, I'm thinking 3:73 because I drive 90 miles round trip.
So I guess 3:73 are going to be good for me. If you don't think so, please give me some numbers, like 80mph@xxx rpms, so I can see where my cruising speed will be with the gears.
I am really in a HURRY to get these as my modbug has bitten DEEP! So please everyone give a different example of what gears you have and at 80mph in 5th give us your rpms. ' Preciate it.
HARD DRIVER is offline
Old 08-17-2005, 04:17 PM
MarcusM
MarcusM's Avatar
Default RE: Buying my gears need advice
Search
4.6
Gears
MarcusM is offline
Old 08-17-2005, 04:20 PM
langod
langod's Avatar
I got 3.90s 'cause I wanted more than 3.73s (which a lot of people say aren't worth it) but less than 4.10s (cause I drive in the winter too.)
With 3.90s I'm turning about 2500rpm at 75mph in 5th.
langod is offline
Old 08-17-2005, 04:26 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
https://mustangforums.com/m_600073/tm.htm
Dan04COBRA is offline
Old 08-17-2005, 04:43 PM
The Great Cornholio
I ♥ Acer
The Great Cornholio's Avatar
3000 rpm at 90 mph in fifth with 4.10s
The Great Cornholio is offline
Old 08-17-2005, 04:51 PM
HARD DRIVER
Damn. Almost all my driving is on the interstate and IF I come across any races they are usually from 75 to 130 or 140. So I really want to have the combo to win at hi speeds. Just in case. I don't plan to go that fast but I like to have the ability to do so.[8D] Everything says 4:10's. I guess I'm just being a puss and am scared it will be too revvy and not daily driverish like I need. Will someone post their shift points and mph and rpms up to 130 or so.
Old 08-17-2005, 06:27 PM
buster
buster's Avatar
3.73 is the way to go my friend. +400 rpm across the band. 4.10s, u may as well have a 4 speed trans.
buster is offline
Old 08-17-2005, 06:44 PM
sandcracker21
sandcracker21's Avatar
ORIGINAL: langod
any gear whine? how much did the install cost?
sandcracker21 is offline
Old 08-17-2005, 07:00 PM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: buster
I disagree.
code3GT is offline
Old 08-17-2005, 07:18 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: code3GT
ORIGINAL: buster
I disagree.
I also disagree, buster, get out of the 70's with that kind of thinking. We have had people with real world knowlage post that they run about 3000 rpm at 90 MPH with 4.10's.
JD1969 is offline
Quick Reply: Buying my gears need advice
