LT's
I run headman headers, took a day to do. Removed the motor mounts, and tilted the engine side to side. I also pulled the starter and linkage. Be careful pulling the old studs out of the heads/installing new hardware, I had to chase a couple of threads to make it work.
Well you should probably take into consideration that most people don't have the experience you have. First time when I dropped my K (had very little experience) it took the better part of the day due to not knowing exactly the best way to go about it. The next time was much faster. For someone who isn't experienced it is a big task IMO.
like oxford said ppl make it sound harder than it is...its like doing gears, very time consuming. I have done my headers multiple times due to exhaust leak and swapping out k members and switch for tubular...if you plan on going tubular nows the chance to do it. dropping the k member is bar far the easiest way to do it. Do yourself a favor and dont get the pypes long tubes, i have them and yeah they are great for the money they are not worth the hassle with the steering rack rubbing and what not, you do get what you pay for im afraid
one of the worst headers.I personally know three people that had
header leaks after installing BBK longtube headers.You definitley get what you
pay for.
The first time I ever installed LT's on a 2v mustang it took me 6 hours. But only 3 of that was actually installing the LT's. The rest of the time was the tubed K, A arms, coilovers, full exhaust, and upper and lower control arms. They are not hard at all. I'd rather install LT's then change a clutch.
There are headers out there that will allow you to drop the trans with the LTs still installed.
To the OP, the install will take a while. I found that dropping the K member was the easiest way and least frustrating way of installing LTs. What does this entail? Well dropping the whole front suspension. I just drop it about 6-8" and hold it up with jacks. Makes for a much easier re-installation.
