Aftermarket flywheel: steel or aluminum?
I agree, on a street car, full or near DD, the replaceable inserts on aluminum flywheels are a big PITA once you have burned out the original one--they never seem to fit properly and often (again for street/DD use) require that you pull the f/w and have the new insert turned to make it tolerable. If I had one (and I have, and did) I would just do that routinely when replacing the insert.
Two of my friends that had their aluminum flywheels fail were
Spec aluminum flywheels and I don't think it's a coincidence either.
Another Spec product fails.
One more thing...I would like to get ARP flywheel bolts but I am having trouble finding which ones are the correct ones to get.
FRPP sells this kit of bolts which is supposedly for all modular 11" flywheels: http://www.fordracingparts.com/parts...tKeyField=8457
it's 10 mm X 1.5
But all other sites which sell the ARP bolts for our cars list this one:
http://www.summitracing.com/parts/ARP-254-2801/
Which are 10 mm X 1.0
Anyone know which size is the correct one for my 04 GT?
it's 10 mm X 1.5
You can use a pin punch to drive the dowel pins from the old flywheel and reuse them (drive them out from the front-to-back of the flywheel).
Here's the procedure from the shop manual.
They are vital to properly aligning the pressure plate assembly! You WILL have vibration and odd-engagement is they are not used, and I have seen more than one botched installation where they were not.
The gasket was for the passenger side X-pipe to exhaust manifold connection--it came out in pieces and had to be replaced. You may want to pick one up "just-in-case", or just to replace it anyway...
It looks like the ARP might be for the Cobra FW (8 bolts).
i love my aluminum FW, its the Spec one and its pretty sweet. i also have the aluminum DS and this thing revs fast as hell,only bad parts is taking off from a stop or something you gotta give it a little more gas. no chatter either
Spec's products, like most things made by man, fall into two broad categories; those that work and hold up well, and those that don't.
The problem with Spec specifically is that their stuff which falls into the second category seems to be a dis-proportionally large chunk of the total, much higher than with most manufacturers--there is no way I'd install one of their clutches
(FWIW, these are individual photos of separate failures, accumulated from the web in less than 5 minutes using Google).
09-24-2015 09:18 PM
09-10-2015 08:39 PM
