Cylinder Head Question - MustangForums.com
Old 11-15-2010, 01:12 PM
crimsonangel
Default Cylinder Head Question
I was directed to come here for some help.
I have a mercury 1994 Grand Marquis that has a ford 4.6L Cast iron V8 Engine which to my knowledge is the same block that is used in the Mustang GT.
My Drivers side cylinder head needs to be replaced and I cant really find any heads that are said to fit my car and the machine shop that my block is currently at wants around 400 for a used head so I found a pair of mustang GT cylinder heads online with casting number F5ZE and year 96-98.
My cylinder heads have a casting number of F5AE. If I get the mustang head I plan on replacing both heads as to not have an potentially unbalanced engine.
my Question is will the heads fit my block? my primary worry is that the head gasket and bolt pattern may be different. Whats the difference between the F5AE and F5ZE casting numbers?
Heres the link to the mustang heads
crimsonangel is offline
Old 11-15-2010, 01:44 PM
SVTeeshirt
Yes, the heads will fit,
idk what you use the car for, if its just an A-B car or if you want some performance out of it, if you're looking for performance go with 99-04 mustang GT heads, might as well throw the cams and intake on too while the heads are off.
If the car is just a point a to b car the 96-98 heads will give you less power (probably about the same as your car stock) but will work.
SVTeeshirt is offline
Old 11-15-2010, 02:23 PM
crimsonangel
Its more of just a point A to point B car, extra power would be nice but not much of a concern. Another thing I thought about is my stock intake manifold and valve covers. would they also fit the mustang cylinder head?
Old 11-15-2010, 02:35 PM
lizzyfan
Underboss
lizzyfan's Avatar
yes the intake will fit
lizzyfan is offline
Old 11-15-2010, 03:25 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
everything will swap over as long as you keep it 1998 or older
WhiteFoxGT is offline
bconboy
09-21-2015 01:52 PM
Mikett
09-12-2015 11:52 PM
cbird1177711
09-02-2015 09:51 PM
cbird1177711
09-02-2015 05:12 PM
Quick Reply: Cylinder Head Question
Featured Sponsors
