just a quick tune question
11-18-2010, 07:57 AM
TECH SAVANT
Quote:
Originally Posted by
StriderTacticaL
^^ Is that actually true? In terms of your odo being off if you don't calibrate your speedo properly according to your gear ratio?
Yup, on both the older cable driven and newer digitally driven indicators the odometer is driven by the same input (cable or SCP data).
Quote:
And to the OP, why don't you just tune be readjusted so the speedo will be fixed for your stock gears?
Good question! I missed that he had the SCT tuner, he can just use it to reprogram the read-end gear ratio...
11-21-2010, 03:45 PM
so i plugged it back in, and the speedometer is off, lik eyall said. so thanks!
and it shifts alot harder than usual, is that fine?
11-21-2010, 05:30 PM
did you adjust shift firmness on the tune.....?
11-21-2010, 05:35 PM
TECH SAVANT
TEXASx2000xMUSTANGx
"Plugged" what back in?
djbigskrilla
09-20-2022 01:04 AM
richard1027
09-09-2015 07:23 PM
richard1027
09-08-2015 01:24 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
CarrieS
09-01-2015 01:00 PM
