Water causing the engine not to start??
Old 12-04-2010, 09:49 AM
98fastgt
98fastgt's Avatar
Default Water causing the engine not to start??
So when i went last night and VERY GENTLEY sprayed the engine compartment out, the car would not turn over. After 3 tries, i had to mash the gas pedal to the floor and start the car, which worked.
EVERYTHING IS ATTACHED PROPERLY and when the car finally did turn over, it idled at 2k rpm for about 5 minutes. I then shut it off, waited 3 minutes, and it fired up like normal. Like nothin happened.
Why? Do i have an issue with my plugs somewhere? Is water getting somewhere that i havent noticed?
When i sprayed the engine off, i DID NOT use the high pressure spray gun at its full spray mode. I simply just held the gun and rinsed the dust off without sqeezing the trigger.
I will also be putting up sound clips tonight of the start up issue that i am having just on a normal day, which is really making me think that i have major plugh issues. Thanks for the help!!
98fastgt is offline
Old 12-05-2010, 01:07 PM
cisurfer
cisurfer's Avatar
take it out for a spin and rip on it and it will be fine the water will burn up...same thing happened to me...i washed it all down and didnt cover up anything...trouble starting took it out and ripped on it and its fine
cisurfer is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
Calizic
08-28-2015 01:46 PM
KEM Motorworks
08-14-2015 10:13 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Water causing the engine not to start??
