Intake Plenum and TB installation
I'm going to be installing a C&L Intake Plenum and BBK Throttle Body tomorrow afternoon, I set aside the tools to get the job done so it will hopefully be quick and easy. I just had a few questions for those who have done it before.
Bolts for plenum: Can the stock bolts be used? Or do I need to purchase replacement bolts?
Throttle Cable Linkage: Do I use the stock one for that as well? If I use the stock one, does it need to be adjusted?
Throttle Position Sensor: Do I need to do anything with this besides swap it? I noticed people have been saying something about a mutlimeter being needed to set it. Is this something I need to worry about?
Installation: I'm not sure how to remove the throttle cable linkage. It looks like the right side of it (facing front bumper) is just screwed on, but the left side has a few connections. Any ideas?
...anything else you want to add along with the installation that you think would be useful?
RE: Intake Plenum and TB installation
Stock bolts can be used. I swapped a sotcker for a C&L in the parking lot of Baytown raceway during FFW.
Dont adjust anything. Take the two bolts out off the bracket and bolt it right back down to the C&L.
You wont need a new one if you be really careful with the one you have now. If you drop it then it can be thrown out of configuration and you will then need a new one.
You will take two bolts out of the bracket and then the connections out of the TB. This is actually an easy task. Just mess around with it for a second and you will get it.
Get a new gasket in between the TB and and plenum. The EGR should be safe to be reused. MAKE SURE YOU DONT CROSS ANY THREADS!!! They will cross thread easy and you will strip them even easier if you put a wrench on them. Rule of thumb is, they will/should screw down 3/4 of the way by hand before you need to put a wrench on it. This goes for all the bolts you will install!
If there are any inperfectins in the casting then get a Dremmell and smooth them out before the install. Dont worry about messing it up... just keep it even.
I think thats about all. Ive done this three hundred million gazillion times.
I have everything disconnected except for the black plastic piece that attaches the throttle cable to the back side of the throttle body. I don't understand how to take this off.
It looks like there is a plug next to the firewall that is attached to the bottom of that rotating plastic piece that I can push down with a screwdriver and pull off, but it's extremely hard to get off so I stopped for the moment.
How do I detach this piece, it's all I have left!!!
I have the throttle cable removed now, had to open the butterfly to take up the slack and pull down on it. It slid right out with the aluminum cylinder on the end.
All I have left to take off is the black cable that is attached to the bottom of that black plastic piece.
Any ideas? All I have to do is release that connector, or is there more to it?
cardsrus1
19
09-15-2015 08:37 AM
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
