Winter Projects???
Winter Projects???
Have you guys started on your winter projects yet? I'll start the ball rolling. So far I've bought and installed J & M CC plates + a front end alignment, 2 new front tires, KB BAP, MM LCA's and will be getting redynoned on the 21st of Dec. After that I'm gonna upgrade my brakes, install some UCA's and that should do it for the winter. What about you guys? What have you done so far or what's your plans?
Didn't start yet but im doing a whole back end. 8.8 housing with welded axles tubes, detroit true-trac posi, moser 31 spline axles, 4.30 gears. Team Z double adjustable lowers, team z upper arms with relocation. 15x10 rears wrapped in 295/65/15 and skinnies up front.
I have recently just finished up my motor build, but it is still sitting on the stand. Over winter plan on getting this in the car, purchasing my glenns performance fuel setup, AIS stage 2 meth kit, and just need my skinnies for up front.
Bought a romeo motor and stage 3 ported heads and finished piecing together my edelbrock intake setup and my fuel setup. Will be putting it all in sometime soon along with swapping m CMS stage 2 cams into it. Hoping for 330-350 at the wheels when its done.
I've got to fix problems,
Install new gears, install new clutch, fix my wheel hop issue... I was hoping to get a set of cams this christmas but I just spent $660 on another root canal lol
Wanna do some cosmetics too
Centerforce Clutch/new flyweel, wheel bearing, Mac longtubes, VRS o/r X, and depending on a few different factors we'll be looking at either intercooled KB 2.1 or intercooled Procharger D1. Car is garaged for the winter and not going to be touched until probably April. Supercharger install around May time (before OCMD spring cruise).
So far I've purchased the wheel bearing. Yeeeaaaaaaaa!!! lol
