Help, water leaks inside the floor boards on passenger side!
Just like title says, I just noticed the water goes inside my car on passenger side. I can't find the source of the leak. My car is convertible but the water doesn't come from the top.
I've read in other forums that there was a problem with the 05 mustangs having something similar to this but mine is a 1999 Cobra.
Check to see if the Drain Tube for your A/C is clogged and or not connected to the drain outlet, it happened a lot on jeeps and also once on my 1114 in Iraq. Even though you might not be using your A/C.
I had a leak on my driver side, but in my case it can apply to the passenger side too. There are some grommets in the door jam that water was leaking on mine. Check there to see if it is placed on properly. Mine was damaged some how and water was coming in.
